Posted by wisbaker on March 19, 2012 at 13:17:04 from (207.118.181.99):
In Reply to: 400 LP questions. posted by Fullers Farmalls on March 19, 2012 at 12:18:34:
Procedure varies form unit to unit and what you're local authorities will allow. At worse you'll have to get your LP tank set up with a pump and vapor return line. With that set up you hook two hoses from the tank to the tractor open the valves on the tank and tractor and turn you pump on pumping liquid propane into the tank and allowing gas/vapor back. Everything on the tank needs to be explosion proof wiring. I have used other systems where we vented the vapor return to the air but I don't know if that is allowed any more. No you can't use natural gas, it won't liquefy, your propane system won't handle CNG and you'd need a compressor to to increase the natural gas to a usable pressure. The tractor pulls liquid propane out of the tank through a heat exchanger that turns it into gas that mixes with the air at the carburetor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
