Posted by D Slater on March 23, 2012 at 07:43:03 from (184.15.12.250):
In Reply to: M&W posted by mkirsch on March 23, 2012 at 05:07:44:
Jim already mentioned this but there's a bunch of splined teeth that have to slide a little when clutch is released. If rust or sometimes thick oil gets in there they will stick. Or if its making a noise the bearing that holds pressure on the discs may be bad especially if it wasn't greased regular. Also if not used regularly they will stick, most times using the tractor a bit with handle released and hitting the brakes will break them loose. If the discs are stuck bad it makes it a harder job when getting them apart.
Not bad to remove one from a SM. It can all be done from the outside. After the hand clutch parts are off the bull pinion comes out like a regular SM and a regular bull pinion and related parts can be installed.
This post was edited by D Slater at 07:49:29 03/23/12.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
