Posted by jdjack on March 24, 2012 at 18:59:25 from (174.124.99.68):
I am working on my fathers farmall B. With the throttle level all the way back in idles slowly and sometimes will die. Then if the throttle is moved at all foward, it speeds up alot and while level is being moved it doesn't change rpm until it gets to about 3/4 and then rpm increases. The hole in the lever (connected to the governor) on the left side that connects to the carb throttle plate is worn out and has some slop. On the right side, the shaft that goes from the throttle shaft to the governor, has 2 springs by the gov, the one is the front doesn't look right, short and big the one in back is long and small. Can the springs, and lever on the left side still be ordered?
can somebody post some instruction on how to adjust the linkages on these? It has a new carb, but problem was their before it was replaced. We have another on that runs and idles great and increase speed as you increase throttle.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
