Re: 350 iner axel bearing row crop
Posted by jal-SD on March 25, 2012 at 08:50:48 from (208.53.222.169):
In Reply to: 350 iner axel bearing row crop posted by Thomas Thorn on March 25, 2012 at 06:28:00:
We did that on an H with a mounted 24 picker on it, out in the corn field, back in the day. Big job, but it can be done. (At least you won't have to remove the picker's elevator before you start.) When you removed the axel bolt on the bull gear & jockey the bull gear around, be careful, the cage that keeps the bearing for the counter shaft on the brake can break easily. You can fish stray parts out of the bottom of the housing through the drain hole with a magnet and I would suggest you get all you can out before you take the bull gear off. Any stray balls & miscellaneous cage parts can cause you a lot of grief when you work on removing the bull gear from the axel. (My $0.02 worth. jal-SD)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
