Posted by AG in IN on March 25, 2012 at 07:59:42 from (67.236.90.241):
In Reply to: 1963 560 diesel posted by windhillfarmer on March 25, 2012 at 06:52:57:
Early 560's had rear end issues, but if it's a '63, those issues would have been remedied by IH by then.
Everybody complains about the glow plugs. Few bother to replace them. 6 good glow plugs are essential for starting these engines.
If it has the sleeves in the diesel engine that use shims to adjust the sleeve standout, the sleeves don't press fit in the block and can occasionally start dancing around in the bore especially if the proper shims weren't used.
These engines could have used at least a half-dozen more head bolts, but there is no place for them. Head gasket failures are more common than other series of IH diesel engines.
My dad's 560 diesel got to where it was blowing head gaskets about once a year. He had the block bored and sleeves with an oversized outside diameter to fit the new bore for the later style engines installed that press-fit into the block installed. He studded the block and threw the head bolts and the pipe spacers in the trash. No more shims, either. About 5 years and 2500 hours later it has some decent power and no problems. The only thing he perhaps should have done is put a later style head with the bigger valves on it.
A later 560 should have the clutch type PTO that is adjustable on the tractor. It should have a plug on the top that looks like a big nut. With the earlier clutch type PTO's the rear end oil had to be drained and the unit had to be removed from the tractor to be adjusted. There was a band-type PTO used on the earliest 560's.
AG
This post was edited by AG in IN at 08:15:06 03/25/12 2 times.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
