First place to check for air leak is filter cover. Lot of those covers don't fit great and also, some 0-rings get cut putting cover on. Have you changed filter because with a milky oil it may have softened up the filter making it even more difficult to draw oil through it so it goes through the bypass screen on end of filter, plugs that , which doesn't take that much. Aerated oil will turn milky looking also even if no moisture in oil. Not likely though. After checking cover, you can add extra oil to cover possible internal air leaks but may not want to waste new oil if it needs a change which it sounds like it must. Three most likely places to suck air, the cover on filter, 0-ring between front and rear sections of transmission and the o-ring on main suction tube in top of filter cavity.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
