Someone put the distributor in "wrong" and moved wires to make it work. Older engines are simple and it happens more than you think. It's been 35 years sine I had a distributor out of a H or a M. Distributors usually either have a gear on the end and you can put them in as many different ways as the gear has teeth, other have a tang on the end they go in right or 180* off. I'm almost thinking the H has a tang drive, if it's off but not 180* off it means the gears in the front are not timed "right" How to fix- rotate the engine until the timing marks ling up at TDC compression figure out were the distributor is pointing- make that #1 then place your wire in firing order by rotation.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
