Posted by gene bender on March 27, 2012 at 06:31:48 from (207.177.56.105):
In Reply to: Throttle adjustment posted by Gordoro on March 27, 2012 at 05:01:33:
If the input lever is wobbly it can make bad throttle response they can be bushed to remove the problem. To set linkage with engine off remove the clevis going to the carb then open throttle all the way then adjust clevis holding carb open. Mite want to put a vicegrip on the throttle rod before you try to turn the clevis. Getting the clevis free helps adjusting for the correct length. A local machine shop should be able to rebush the input shaft if not send it to me as i do them all the time.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
