Re: Behlen Power Steering on 400
Posted by mkirsch on March 28, 2012 at 05:37:18 from (64.80.110.75):
In Reply to: Behlen Power Steering on 400 posted by NE_Red_Rookie on March 27, 2012 at 10:41:01:
I've seen the Behlen unit on a 400 before.
If you don't use some sort of priority flow valve, you'll have NO steering whatsoever, because all the oil will flow through the open center valve stack, and won't develop any pressure.
It's a lot easier to use the Behlen pump and reservoir, rather than trying to plumb it up to the live hydraulics. Keep the two hydraulic systems separate.
The Behlen pump and reservoir system should bolt right up to the 400. The engine and frame rails up front are pretty much exactly the same as an M. Only difference is the hood, and there's more room under the hood for the reservoir.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
