Posted by pete 23 on March 30, 2012 at 11:00:30 from (74.32.231.176):
In Reply to: Farmall M Carb posted by Garage Dog on March 29, 2012 at 18:12:25:
Noticed you said l 9/16 float setting. That is way off. It should be 1 5/16. The float must lay parallel to bowl surface. They are tricky to keep from rubbing on sides of carb. New needle and seats are often poorly made, however, the ones I have been getting lately from CASEIH have been the good looking ones and they work good. I have coined many seats on the others over the years. Because I worked on so many carburetors for so many years I took an old carb bowl, cut the bottom off and use that for a gauge for adjusting the float. Did that after I had to run out to a farmers place to reset a couple after working on them. The idle mixture screw on an M is an air bleed, not mixture like a lot of carburetors. So, if you have to have it all the way in , limiting the air at idle you are running lean. Low fuel level, plugged passages, wrong idle jet. Good luck.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
