Posted by Pete P. on April 04, 2012 at 18:08:10 from (65.189.199.106):
Hello all --
The '47 cub PTO still won't stay engaged. Renewed PTO pilot bushing, replaced shift lever & collar, checked rear PTO shaft bearing - still staked down and appears to be fully rearward. I still have nearly a half inch of distance between the PTO shaft and trans. mainshaft. I've read that the front mainshaft bearing retainer may be installed backwards or may have failed allowing shaft to move forward. I've never had the trans apart as everything (except PTO) works fine and has for 10+ years, but I'm out of ideas. I would think if the mainshaft moved then gears woudn't line up and the clutch would not have enough room to separate and none of that is the case.
How much of a pain am I in for to check / replace that mainshaft bearing? I assume I need to split the tractor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
