Re: cub 154 governor question
Posted by screwstick on April 03, 2012 at 16:01:54 from (174.24.117.103):
In Reply to: cub 154 governor question posted by casefrank on April 03, 2012 at 14:41:47:
The cable will pull the lever on the governor till it hits a positive stop, that can be adjusted by the bolt on top of the governor. With a helper present, loosen the cable clamp, and manually pull the lever till you reach the desired RPMs, adjusting the bolt stop as necessary. When the RPMs are where you want them, and the throttle lever in the full/high position, tighten down the cable clamp.
If the spring is weak, it will also not allow you to reach high RPMs.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
