Re: 826 rear diff drain plug issue
Posted by TJV on April 05, 2012 at 05:01:50 from (67.230.241.17):
In Reply to: 826 rear diff drain plug issue posted by Jeff Gibson on April 04, 2012 at 18:36:34:
I have in the past I have welded a bolt into the hole then let it cool and put a wrench on the bolt head and turnd them out. use the biggest bolt you can get into the stripped out square hole maybe even grind the threads off a little to be able to use a bigger bolt then weld around it the heat from welding also hepls to make break the plug loose or at least when it cools it shrinks a little making it come out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
