Re: farmal h
Posted by minn.meyer on April 05, 2012 at 06:05:53 from (65.55.67.184):
In Reply to: farmal h posted by paul vroman on April 02, 2012 at 15:31:52:
If there is water in the cylinders.Can you get electricity to it?If so take a shop vacum reduce the hose down enough that the hose at the end will fit in a spark plug hole.Suck the cylinders out,check to see if there is water in the crank case.If so drain it.Then pour deisel fuel into each cylinder.Put the plugs back in,let it sit for a week or a little more.Then try to turn it over with a 12 volt battery.With the plugs out.If it still is stuck let it sit some more.Deisel has much more detergent in it then any ATF you can find.Good luck!!!!!!!!!!!!!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
