Posted by TimWafer on April 06, 2012 at 12:34:20 from (69.193.106.146):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
Still working on adjusting this axle. Pretty much have tried all the suggestions including bumping into a wall & driving it around a while with the clamps & pins removed. Also removed the spindle and replaced it with a 5 foot heavy walled pipe and pulled the end towards the rear axle with a come-along until the pipe was bending. All the while heating and hammering on the tubes. The tubes haven’t budged even a hair.
So finally have removed the entire front axle and stripped it down to just the outer axle tube and the two adjustable insert tubes. Tonight will rig up a better way to heat it and can at least get a good swing at all sides with a sledge now. Then may weld up some brackets so I can use a 20-ton jack to try and push them apart. I blew apart a 12 ton jack already but didn’t have it really squarely aligned hence the need for the brackets.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
