There are four bolts between the hub and the housing on the outside that holds the bearing and seal in, this needs to be unbolted since this piece will come out with the axle. Like was said earlier the cap on the inside needs removed, and the nut and bearing taken off the inside. On this I just let the bearing slide off of the shaft as I pull it out. Make sure you support the bull gear as this will drop out of there when you pull the axle shaft out of there. good luck
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
