Posted by pete 23 on April 09, 2012 at 17:39:58 from (74.32.231.176):
In Reply to: Push rods on a 1947 H posted by John Fulton on April 09, 2012 at 14:54:48:
No problem, but you should reset valves after running long enough to get warm as those push rods will work their way into place. You can usually prove this out pretty easy by , running an engine for a while, check the clearance on a given valve with engine turned to proper position for that valve, then just grab a hold of that rocker arm and move it taking up the clearance. Now, recheck your clearance. If every thing is not brand spanking new the clearance will most likely be different. That is why you run them, check clearance before even touching the rocker arm as it has found it's running home. OH, .017 on an H.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
