Posted by riverbend on April 09, 2012 at 18:09:24 from (74.46.181.156):
In Reply to: 350 T/A clutch update posted by riverbend on April 08, 2012 at 06:23:31:
Cub149, Thanks for the measurements. I'll check the flywheel depth in the morning.
Jim's comment about the clutch pedal having to move the T/A crossshaft as much as the lever got me thinking and the cartoon light bulb over my head started to glow.
The tractor came with the modified T/A crossshaft shown on the right in the picture above. I replaced it because it looked like a broken part that had been improperly repaired.
Calculating the tangent of the angle that the modified shaft would turn using the motion of the clutch pedal gave the same amount of rotation as using the T/A lever. The shorter arm equals more rotation and more lift at the pressure plate.
I have not reinstalled the modified crossshaft yet because there seems to be an underlying problem that is not found on other 300s, or 350s (or SHTAs) that should be fixed...
To check if the T/A clutch was slipping due to the shimming, I hooked up a field cultivator and ripped up a patch of quackgrass while pulling up hill. The load was enough to stall out the tractor. Rather than use the T/A I pushed in the clutch, let the rpm recover and let the clutch out again. After about half an hour of this the T/A clutch temperature was 86 degrees F.
I think that the T/A clutch clamping pressure is adequate for the amount of power this tractor is making.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
