Posted by strikefalcon on April 10, 2012 at 19:26:22 from (184.20.104.64):
In Reply to: 450 charging posted by Greg Hammel on April 10, 2012 at 18:59:30:
do you have a multimeter? read the voltage across the battery terminals with- key off, key on, key on and running hi idle. the voltage should be highest running hi idle. check belt tension and look for obvious things like corroded connections, loose wires, bad switch etc.then go from there. find a schematic to make things easier. good luck.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
