Re: 300 Utility Not Running
Posted by Janicholson on April 12, 2012 at 19:44:04 from (96.24.99.126):
In Reply to: 300 Utility Not Running posted by Briar Hill Brittanys on April 12, 2012 at 18:26:31:
1342 from radiator toward rear. Top right on cap
(facing forward, looking at the cap) is #one,
bottom right is #3, bottom left (toward block) is
#4 top left is #2.
Clean and tidy using electrical system spray to
take out the residual Glycol (a sugar) from the
distributor. Set the points at .020".
Put a dab of grease on the rubbing block of the
points. Drag a folded dollar bill through the
closed points to clean them.
Do not change the timing, it was running, and if
so it will be very close.
Be sure the fuel is on, and (if no firing, take
out the spark plugs heat them (business end
only)with a propane torch for one minute each,
then put them in (use a rubber hose to keep burnt
fingers to a minimum) and start it. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
