Re: 1955 IH 300 carburator
Posted by rustyfarmall on April 13, 2012 at 12:02:04 from (216.248.71.224):
In Reply to: 1955 IH 300 carburator posted by Country Doc on April 13, 2012 at 10:31:35:
If you lost the high speed idle adjusting mechanism, the tractor would most likely NOT run, and gasoline would be leaking profusely from the hole. Likewise if you lost the 1/8" pipe drain plug, gasoline would be escaping at a very high rate of speed. However, if you lost the welsh plug from the hole in the very bottom center of the carburetor, the tractor will still run, and gasoline will NOT be leaking out, other than MAYBE a drop or two sporadically. There is a felt filtering material that goes in that hole, and then the welsh plug is "driven" in to keep the filtering material in place. Any Case IH dealer should have that plug on hand. Any auto parts store will have a plug that will fit, but the plug from the auto parts store will need a small hole drilled directly in the center.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
