It sounds like may well be pressure switch under the floor board. They were known for problems of leaking internally and causing switch to close with equalizing pressure on both sides of the contacts. (Yes, the side you are operating in runs on an open circuit switch). In fact, you can unhook the affected side to see if the switch is the problem. It will only operate in that side then. I would not recommend using the bypass harness. No protection for lockup of both clutch packs at same time which will really tear things apart. The sentry is doing it's job, telling you something is wrong.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
