Posted by Janicholson on April 13, 2012 at 20:00:02 from (96.24.99.126):
In Reply to: alternator puzzle posted by notjustair on April 13, 2012 at 19:05:43:
The L terminal is the vertical part of the T shaped connector socket. The S terminal is the cross bar on the T. The lamp used as a "idiot" light in the L circuit. This lamp is connected with one lamp lead connected to the Alt L spade connector, the other lamp lead is connected to the coil (where the ignition power from the switch is connected. (if it has a ballast resistor, it is connected at the ignition switch side of that device.) If the use of a diode is chosen the diode is placed in the same place as the lamp, with the band end of the diode toward the alternator. If a resistor is used, (10 ohm) It is placed in the same way as the light. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
