Well on that subject here i am no expert BUT when you look at the HP of the LP they usually are a little lower . Then you run into the problem of filling them and having the tank. . I just got home a little while ago from the farm and the new piston is in the engine and other then some clean up and chasing the head bolts and the block and a final clean up of the deck and head she is just about ready to go back together . If it was not for getting chores done i would have probable had the head back on . One new Clevite Piston MADE IN TURKEY one new set of rings Made in the USA and a Victor head set and at this time unknown country of MFG. as i did not look yet. So now all i need is a few more hours of NO rain and it will run again . I may go back out to Ohio Twist drill and have Lee make me a ream a whisker bigger and ream the main fuel jet a couple tenths of a thousandths and fatten up the fuel mixture a little more . what would be nice is to remachine the carb so that i could use Holley jets and just unscrew one and screw a new one in . with alkihol ya have to really play with it and the down side is WEATHER conductions . Years back my one friend and i played with a built Oil all OVER 1650 with a bored and stroked engine and we had a holley 4bbl. on it and a TO4 turbo on alki. Lets just say it was a learning curve and we made lots of spare parts in the learning curve . when we were getting close to getting it right the weak point was the head bolts , ya know that at 25 lbs boost you can stretch then over 3/16th's of and inch and lift the head , We over came that small problem and found out that ya know you can literately put the oil pan and crank on the along with all seven of the main bearing caps And the heads of the main bearing bolts on the ground . Then if you make a girdle to hold the head down and the crank up for some reason the side of the block blows out . Maybe a tad to much boost . Playing with plain old gas was a lot cheaper.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
