Posted by pete 23 on April 15, 2012 at 11:20:57 from (74.32.231.176):
In Reply to: IH 5488 shifting?'s posted by Dave from MN on April 15, 2012 at 07:21:10:
All gears are syncromesh except reverse and therefore should be very little grinding of any forward gear and you can shift them when moving. I would make sure the clutch pedal is properly adjusted and you have zero clutch pressure when fully depressed. Not unusual for a little difficulty shifting when cold due to drag of oil in main clutch. Later ones changed the lube to clutch valve for less lube flow on clutch making them better to shift when cold.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
