Posted by rustyfarmall on April 17, 2012 at 13:49:48 from (216.248.71.224):
In Reply to: 263 Gas Motor Missing posted by BigBob706 on April 17, 2012 at 11:54:08:
Do a full tune up. Spark plug wires, distributor cap, rotor, points, and condensor. Might even want to replace the ignition coil, and even though you already changed the spark plugs, don't rule out the possibility that new plugs might not be up to snuff. Also, ignition problems will quite often mimic fuel related problems, and vice-versa, so make sure the carburetor is not set too lean.
Unless you are running that tractor full out, making it work as hard as it can, it will run just fine on the same gasoline that you use in everything else.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
