Something that is supposed to hold water isn't and it's leaking into the cylinders but heck you knew that already. Could be a cracked sleeve, head or block, could be a bad head gasket or maybe monkeying around one of the sleeves moved, don't know if this is a wet sleeve or dry sleeve engine. If it's a wet sleeve it could be leaking at the seals, if it's a dry sleeve it might of moved enough and is preventing the head gasket from sealing. Before I tore it apart again I think I would try spinning it over with the plugs out and see if water comes from all cylinders or only one, an alternative would be to pressurize the cooling system with the plugs out to see if the water is localized. Are you getting any water into the oil? Something else to look at and might help you figure out where it's coming from.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
