Re: 47 H
Posted by Brian on September 21, 2000 at 05:24:27 from (205.188.197.46):
In Reply to: 47 H posted by Dave Sholtis on September 20, 2000 at 16:57:59:
Dave,
Whatever you DO NOT pull it to try and free it. You will more than likely break some rather important parts. This is the procedure I followed to un-stick my F12, pull the head to be sure the valves are free(I had a valve job done in the meantime). Then I pulled the oil pan to get at the underside of the crank. I then filled each of the cylinders with penatrating oil, then took a block of wood small enough to just fit into the cylinders. NOTE: be sure to use as large a piece of wood as possible so you don't punch a hole in the top of the pistons!! Then every day before I went to work and when I got home I would smack each piston with the block of wood and a hammer then I would smack each crank arm journal with the block and hammer. And by the time the head was done with it's valve job I had the motor free!!
Good luck and take you time!! Brian
Post A Followup
: Re: Re: 47 H
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
