I suspect you blew the 6V coil by running it on 12V power, or burned the points, or both. 1964 should still have a 6V system.
The ammeter swings all the way over to the right when you turn on the ignition switch, right? That means the tractor was 6V positive ground originally and you are running 12V negative ground...
...AND you have a DEAD SHORT somewhere.
Don't leave the switch on now, or you're going to start smelling the distinct odor of burning wire insulation. You need to inspect the wiring looking for burned, or bare wires, just in case there's a short there preventing it from starting.
The short may be in the coil, or the points may have welded together too.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
