Re: IH 184 Carb Problem
Posted by wayne in mn on April 21, 2012 at 19:24:04 from (24.179.181.201):
In Reply to: IH 184 Carb Problem posted by KDougM on April 21, 2012 at 18:50:41:
The needle & seat are not shutting off inside the carb.
The float may be damaged and getting too heavy or the needle/seat combo are leaking. Replace as needed.
Shut off the fuel flow at the tank each time you are finished using the tractor to help stop leaking when not running.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
