It may be by passing in the cylinder . Now if it has the org. cylinder there is a pin that sticks out of the top of the cylinder under the flipper plate as i call it and you can raise the hitch up to where you want it and press this pin in and it should hold the hitch at the desired hight untill ya want to lower it then you just move the hitch control lever to the UP position for a second and it will pop the lock pin back up then you can lower the hitch.Keep in mind that your working a tractor that has had extensive field testing and may be getting wore out and your problem maybe leakage thru the control valve.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
