Re: Timing a Farmall H Tractor
Posted by El Toro on April 26, 2012 at 05:48:29 from (108.3.225.57):
In Reply to: Timing a Farmall H Tractor posted by Picklesmith on April 26, 2012 at 05:03:58:
Remove the sparkplug near the radiator and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure. Once you feel pressure drop a long plastic straw on top of the piston then you watch
the straw rise while the helper cranks the engine. When the straw quits rising the No1 piston should be at TDC on the compression stroke
and the timing marks should be aligned with the pointer. The rotor should also be pointing to the No1 plug tower. Hal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
