Are you trying to remove the glow plug alone or the entire injector? You should be able to remove the glow plug itself just by unscrewing it from the injector. Removing the injector nozzle is similar. Removing the entire injector unit is difficult. If you do not have a suitable puller there are two options:
Either:
1). Disconnect the high pressure fuel lines from the injectors.
2). Loosen the two nuts on each injector unit - not too much.
3). Turn motor over on the starter motor until the injectors loosen.
DO NOT remove the two nuts. If you do, the entire injector unit will be ejected from the cylinder head at high velocity and could cause serious injury.
Or:
1). Remove cylinder head.
2). Take head to cylinder head repair shop and ask them to remove the injector units.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
