Posted by Yooper Farmall on April 30, 2012 at 07:36:28 from (141.210.112.16):
The upper plow assembly connects to the lower moldboard assembly via two steel plates sandwiched together
The wrench is on one of two 5/8” bolts that connect the upper assembly to the sandwiched steel plates.
The two empty bolt holes on the bottom of the plates takes one ¾” bolt (front) and one 5/16” bolt (back)
The 5/8" bolts are pretty good sized, but it struck me that the lower bolts were a larger 3/4" bolt paired with a much smaller 5/16" bolt.
Could it be that the 5/16” is meant to sheerer if you hit a big rock, making the whole arm pivot on the ¾” bolt and flip the moldboard back?
I've heard of break-away hitches on pull behind plows.
I believe all the bolts on the plow were grade 2, I replaced them all with grade 8. If this 5/16" bolt is meant to sheerer I'll have to replace it with a grade 2.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
