Posted by Roland Phillips on April 30, 2012 at 17:24:12 from (173.26.41.234):
I’m early in the process of restoring a 1929 22-36. I’ve had the head done. The bottom of the engine is good. I cleaned and put the carburetor back together. It’s the side draft brass version. I’ve put it back together and got it running. It runs on three cylinders except for engine acceleration, that is, from a slow idle to a fast idle. During the acceleration, it hits on four, then back to three. The plugs in cylinders 1, 2, and 3 are dry and clean after running. Number 4 is not as clean and slightly wet. I’ve changed plugs (using both 3076’s and 3077’s). Plug wires are new. I’ve changed magnetos. The current magneto throws a good ¼ inch blue spark and starts and runs an F-20 fine. Compression on all cylinders is about 75 lbs., and can be verified by a hard pull on the crank through all four cylinders. I’ve squirted oil around the rear intake manifold gasket while it is running to check for vacuum leak with no change. I feel like it must be a vacuum leak, but can’t figure out where it could be considering the construction of the head (primers are gone with brass plugs in their place). All the valves operate smoothly and all have more than sufficient lifter to valve gap. I have three running F-20’s (one overhaul and lots of tweeking on them), so I’m familiar with the engine type. I’ve about run out of ideas and any help would be appreciated. If you think conversation is in order, send me an email and I’ll call you on my dime. Thanks, Roland
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
