Posted by John T on May 02, 2012 at 05:20:33 from (216.249.82.117):
In Reply to: 6 volt cranking amps posted by longear on May 02, 2012 at 04:45:35:
Nowadays I see CCA as a common or most prominent displayed rating on batteries. It may have the reserve capacity also. In years past Id see Amp Hours as the more common label. If you get into Amp Hours thats more of what I view as an "energy storage capacity" while CCA is more of how many amps can it pump into my starter for how long before the volatge drops to x volts. Its that initial short term high current you need to crank the engine esp when its coldddddddd so you need a regular starting NOT a marine deep cycle (longer slower gradual deeper draw) battery of course.
If youre most interested in getting her started and then allowing time for her to replenish (which is the design for starting batteries) LOOK AT CCA and the more the better
If youre more interested in a lower current deeper draw longer operation time (Marine trolling motor batteries) then look at Amp Hours (energy storage capacity)
REGARDLESS, OBVIOUSLY THE HIGHER EITHER NUMBER THE MORE BATTERY AND ENERGY STORAGE YOURE BUYING
NOTE for 6 volt applications I advise people to buy the biggest heaviest highest CCA rated battery that will physically fit in the space provided. If you have that and use 00 Gauge Battery and Ground and Starter Cables with a good solid heavy ground and have the engine well tuned and the staretr in good shape THEY OUGHT TO STILL START AT 6 VOLTS if you hold your mouth to the right that is
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
