It is easy to make a dip stick. Just remember, the reservoir needs to breath. Use a washer, make the dip stick so it has a flattened end that cannot fall through the hole in washer, washer cannot fall into reservoir. With that dip stick being smaller dia than the hole in the washer it will breath. Another thing, originally the H had a cotton waste packing in the filler cap to act as a filter. I saw a few of those packings find their way down into the pump when someone lost, omitted or the dip stick went down inside. That stuff will stop a pump real quick. Some used a two piece, looped together dip stick when adding the four way valve and when that came apart it also jammed in the pump gears. Some just left nasty grooves in gears and housing , other stripped drive threads, on pump and or transmission drive. Hy tran is too thin for those old girls unless you are more concerned about mixing oils with other equipment. Remember, there is no pressurized wear plates on these pumps to maintain zero end clearance when under pressure, so, you have more internal leakage. Far as detergent oil foaming, how would any one want to have a foaming oil in any engine that uses hydraulic lifters. Foam is number one enemy of those. Detergent oils have additives to disperse the foam, non detergent oils do not.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
