This is an early version of the positive crankcase ventilation system. There is a mesh filter in the vent pipe to filter incoming air into the crankcase. Instead of a PVC valve there is a restriction fitting in the head to limit flow. When the combustion blowby gasses get to be more than the vent in the head can handle, the excess is vented out the tube by the oil pan.
The same system was still being used when the 460/560/660 tractors were released. It was soon eliminated on them because the oil entering the air cleaner assembly was causing too much dirt to build up on the inlet of the air cleaner assembly and would choke off the air flow. That is why on those tractors you will find the little tube on the air cleaner pinched off and a plug in the top of the valve cover.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
