Dirty field control points in the regulator can cause the problem you are having. Cleaning them as Jim suggested will probably correct your problem.
Dirty contact points will cause a higher resistance between them. When the generator is first started up the voltage in the field windings will be very low, possibly less than one volt. You need good contacts to ensure that this low voltage is grounded. With a good ground the field coils will use the small amount of current generated to become electromagnets to add to the residual magnetism in the pole shoes. When that happens the voltage will quickly spike upwards until it is great enough for the regulator to start to control the maximum voltage.
The simple test is to ground the filed terminal on the generator once the engine is started. If that causes the generator to immediately start to work you know the problem will be dirty or loose contacts.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
