Im not up to detailed specs like typical charging currents on a 6 volt system that Bob M or Janicholson may be buttttttttttt from memory 17 amps is fairly high on a 6 volt genny at least if it stays there a longggggggggg time after starting.
I think our friend Teddy may be onto something since if the gennys field post got somewhow dead shorted to frame ground that makes her charge full bore to the max. If the gennys Field post got over tightened or was hit the pass through insualtion may have broke. ID CHECK TEDDYS SUGGESTION and insure the field post isnt permanently grounded?? See what happens if you remove the wire off the gennys FLD post???
If you remove that gennys FLD wire it shouldnt charge much (if alls well) but if it still does at high rate the genny must be shorted possibly the pass thru insultion is broke!!!!!!! If when that wire is replaced it goes to high charge AND STAYS THERE A LONG TIME the VR must be bad (if it has a VR) or the wire from FLD on Genny to FLD on VR is shorted to frame ground CHECK THAT WIRE!!!!!!!!
If it has a 2 wire (BAT GEN) Cutout Relay and uses the LHBD light switch, remove the gennys wire on FLD and see if it stops charging as it should if alls well??????? If not the gennys FLD must be shorted internally or the post insulatiion is bad. If it stays on max charge with that wire connected see if switching the light switch from low to high makes a difference as it should??????? if not the wire may be shorted from FLD on genny up to the light switch.
We could tell more if we knew the battery voltage sititng (6.3) and then what it is running (6.5 to 7)......If it stays much above 7.2 or higher a longggggggggg timeeeeeeee regardless I suspect a bad VR (if it has one) or a shorted genny FLD,,,,,,,,,,,or a short in wire from gennys FLD to light switch (if it uses that)
If the battery voltage doesnt rise to much over 7 I would expect the coil to be warm when running but NOT so hot you cant keep your hand on it.........If the batetry voltage is going to 7.5 or more and stays there a longgggggg time I could see the coil getting fairly hot....
I just cant say sitting here if the ammeter is accurate or why its not swinging to - discharge
BOTTOM LINE I THINK SOMETHING N MAY HAVE GOT BROKE OR SHORTED WHEN YOU WERE DOING THAT WORK.
Maybe if it has a 3 brush adjustable genny the third brush got moved to max charge positiion?????
Maybe the loads (lights) got somehow disconnected from the charging system (BAT terminal on VR or Cutout Relay) that would explain why the ammeter dont swing to discharge and if the genny dont see that load if its a VR system it can affect the charging?????????
I still like Teddys reasoning, maybe the Field wire got shorted????? Its easier if there armed with a VOM but tougher over the net YOU MUST HAVE GOT A WIRE SHORTED OR SOMETHING (FLD POST INSULATION) BROKE WHEN YOU DID THE WORK
SEE WHAT HAPPENS IF YOU REMOVE THE WIRE FORM THE GENNYS FLD POST IT OUGHT TO STOP CHARGING
I hope Teddy and Bob M and Jim and others can help me out here............
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
