Posted by SuperABen on May 06, 2012 at 10:25:11 from (64.203.149.227):
My A has not run in nearly three months. There's a long story there as to why a Farmall tractor lover can't find time to go out and start his A, and part of that includes the reason why I have not taken time to rectify the original problem!
It was originally parked to repair some faulty wiring. The previous owner replaced the generator (6v with relay) to a newer version, still 6v, with a 3 terminal regulator. Somewhere along the way the wiring had been replaced to modify a relay system to a 3 terminal regulator system.
I restored the tractor about a year ago. The engine on this A is perfect mechanically, so I did not perform a rebuild, only a paint job.
~New (previous owner) 6v generator, remake ~New (previous owner) 3 terminal regulator ~Original 4 position light switch ~Original H-4 Magneto ~New (previous owner) wiring to match regulator
After a few months, I noticed the generator was not charging. In the process, I noticed that someone had stacked the "L" load wire on the regulator onto the "Bat" terminal. This was fixed, but when I tested the generator again (engine running) I found that it had no charge. I assume the wiring either burned the regulator or the relay; I have not confirmed that exactly yet.
The next day I went to start the tractor to try another test, but the battery was discharged down to 4 volts. I do have a 12 volt jump start which I have used in the past, so I tried that. Surprisingly, the starter only engaged the flywheel slightly then stopped. I had an extra starter, but it also did, and does, the same thing when hooked up to the tractor. Normally, my 12v jump start will easily spin the engine; it still works fine for my Super A, which incidentally needs more amps to spin than the A.
I have also bypassed the starter switch by jumping to the starter case and the copper terminal, with the same results. Lately, I have tried my 12v jump start straight to the starter, with the generator and 6v completely disconnected, and I still get the same problem.
Obviously, something has gone awry to discharge my battery to 4v overnight, as well as keep my 12v from easily spinning both starters. I also think it is not a starter issue, since both starters have the same problem on this tractor. I hooked up my multimeter and noticed that the jump start discharges down to .5 volts when trying the starter. This may be normal for a 6v, but I would think a 12v would not discharge so low... but I also don't claim to be a electrician!
The only other thing which might cause trouble is a wire I hooked up to ground the kill switch; the switch used to ground itself through me when I shut off the tractor! I attached one end to the knob and one end to the tractor frame. Could this cause trouble, even though I have had this attached for a year with no problem?
Has anyone seen a starter issue like this before? I admit to being stumped! My current solution is coming this week-- a hand crank!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
