Posted by ccaissie on May 08, 2012 at 09:05:22 from (68.238.54.43):
Case 265 cultivator tractor won't start. Starter cranks OK, Glow plugs have current, minimal exhaust smoke when cranking, and have bled the system repeatedly..runs well when it gets going.
There may be an injector pump issue, as it only will start when pulled to get the engine rpms to ~1000. I'd like to check compression and timing.
Anyone have compression specs? Timing suggestions? It hasn't been apart to my knowledge. Should be 200-300 psi, yes?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
