Re: Cub Clutch question
Posted by mkirsch on May 11, 2012 at 05:31:26 from (64.80.110.75):
In Reply to: Cub Clutch question posted by Farmallb on May 10, 2012 at 20:51:00:
You may be able to cure the problem with two simple adjustments.
1. Raise the fingers on the pressure plate slightly so the pedal can get more lift.
2. Readjust the pedal free play so the clutch completely releases, and doesn't "tick" when you have the pedal fully depressed.
You may not end up with an exact perfect free play measurement, but you might be able to eek some more life out of your clutch this way.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
