I have used both detergent and non-detergent oils in various motors. If a motor is old and tired, then I just keep going with the non-detergent oil until I psyche myself up to do an overhaul. Then I run a detergent oil for the last time it works. Cleans out a great deal of the junk all by itself. Basically, if a motor is in good order, with good pistons, sleeves, rings and oil scraper(s) then a detergent oil is fine. If a motor is a bit tired and is keeping compression by virtue of carbon build-up then a detergent oil will very quickly remove the build up and bring the engine rebuild date much closer than might otherwise have been the case.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
