Re: Farmall 300 oil pressure
Posted by NoNewParts on May 14, 2012 at 05:41:50 from (67.240.145.237):
In Reply to: Farmall 300 oil pressure posted by Mark J in Mi. on May 12, 2012 at 08:45:40:
bearings getting worn
10w-30 is a little thin for worn bearings.
15W-40 diesel rated oil will pick it up some if worn.
Put rod and main bearings on your future to do list.
not hard, and you can put a new oil pump cover gasket and
relief spring(if applicable on that motor), and plane the cover
when you are in there.
with that said, I've had tractors that dropped worse. no problems, I
just knew that I would have to roll in new shells when I had the time.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
