Posted by RPM1941 on May 14, 2012 at 11:00:43 from (173.23.76.185):
In Reply to: New 1086 owner posted by Super Steve on May 14, 2012 at 07:01:22:
The TA cable is notorious for seizeing up after years of use, particularly in colder areas, usually the top end is bent, its a little L shape where it goes into lever, threaded into cable. 86 with cabs had a lot of grief with cab mounts (isomounts), you can test with just pushing clutch pedal with engine off, if cab moves up & down they are suspect. You should examine these 2 areas before attempting any adjustments, it might cure a lot of ills.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
