Posted by mkirsch on May 16, 2012 at 05:05:13 from (64.80.110.75):
In Reply to: Yellow Low-Boy Cub posted by CharlieNJ on May 16, 2012 at 03:22:28:
All it is, is a little lever that moves a sliding collar to join the PTO shaft to the transmission main shaft. It could be a matter of the latch plate that holds the lever simply being out of position. It could be stripped splines as you suggest. It could also be the shaft has slid out the rear of the tractor a bit and things are too far apart to engage properly. Could also be worn bearings causing a misalignment, which in turn causes the collar to "walk" to the disengaged position.
Fixing any or all of this is pretty much the same process, and not all that difficult. All the PTO parts can be removed and serviced without splitting the tractor.
BTW, the PTO turns at engine speed, and backwards from a standard PTO. The PTO shaft is essentially connected directly to the engine.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
