Posted by SadFarmall on May 18, 2012 at 19:33:36 from (118.209.141.41):
In Reply to: MD no spark posted by IAtractorKid on May 18, 2012 at 19:12:45:
First thing to do with an H4 magneto is to remove the coil cover (four cheese head screws) and check the contact between the coil and the strip, which connects the high tension wire, leading the centre of the distributor cap. There is often a bit of corrosion or copper sulphate build-up here, which kills the spark. If this does not work, then you need to start pulling the magneto apart. It is highly desirable to have an Owner's Manual and/or Workshop Manual to help you do this. The magnetos are not difficult to work on, but without an exploded diagram and instructions, it is easy to set the magneto timing incorrectly.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
