Posted by luv2wrench on May 23, 2012 at 08:21:32 from (216.170.42.241):
Installed rebuilt Generator (rebuilt by electric shop that does alot of them) Replaced the wiring. Lights work. Still not charging. Light switch seems ok?? Grounds good.
I took apart the Cut out relay before i gave it to the shop to rebuild, looked bad to me, full of rust and crappy connections to me. shop gave me the gen back and said it was ok?? could that be it?
Got BAT wire going to the positive side of the ameter. F terminal to the lower part of headlamp switch, same connection that has a wire to the housing case ground. The GEN terminal was wired to the A post on the generator by the shop that rebuilt it. new battery too.
What i m i missing??? should i replace the $100.00 headlamp switch???
My ameter is a new one that is out of an automotive style guage package that you mount under the dash.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
