Posted by Owen Aaland on May 24, 2012 at 13:14:51 from (216.47.35.138):
In Reply to: 300 making noise posted by old on May 24, 2012 at 12:32:17:
To check noises with clutch bearings, with the pedal released the bearing should not be touching the release levers on the pressure plate and will not be turning so there will be no noise. As you start to press down on the clutch pedal when the bearing starts to touch the release levers the bearing will start to spin and any noise should start then. If you continue to press down on the clutch pedal until the clutch disk is released the pilot bearing will begin to spin as the disk slows down. By listening to when any noise starts you can determine which bearing is making the noise.
In your case the noise happens when the clutch is totally released so if you have the correct free travel in the clutch adjustment the noise is not in the clutch.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
